Midi question
Home Forums Products Rackmount Midi question
Viewing 6 reply threads
    • #169252
      vpajerski
        Does anybody know how the midi thru operates?  I’m using a usb midi controller connected to the H9000 and I don’t see anything on the Midi thru connector.  Do I to have use the DIN ports?
      • #169277
        Puppeteer
          My assumption is that MIDI thru is a hardware thru, so only for use with the DIN ports.  I think there is an option in the setup screen to turn on USB Thru
        • #169280
          vpajerski
            Ok, thanks. I guess I’ll have to get an adapter then.
          • #169284
              That’s correct, MIDI Thru is a hardware thru for the DIN MIDI input. There are no settings for USB MIDI Thru.
            • #169424
              Puppeteer
                I thought that these settings below turn MIDI thru on for DIN, USBA and USBB
                MIDI Feedback
              • #169426
                bsfreq
                  I thought that these settings below turn MIDI thru on for DIN, USBA and USBB MIDI Feedback
                  These are for the controller feedback, to mirror the state of your mapped controls to your controller software / motor faders, led encoders or any other controllers with visual feedback.
                • #169435
                  Puppeteer
                    Thanks for the clarification
