Home › Forums › Products › Stompboxes › Midi switching for all 3 boxes
September 12, 2009 at 10:39 pm #106427
konstantine3
MemberIs there a midi switcher that can controll all three stompboxes from my pedalboard? I dont know much about Midi but Im sick of tiptoe through the pedals dancing
thanks
September 14, 2009 at 8:24 pm #119031
achaput
ModeratorHi Konstantine,
Did you know you can use one Factor Pedal to control all three? Just get two MIDI cables and connect the pedals this way:
[MASTER] MIDI OUT/THRU (set to OUT)
>[SLAVE1] MIDI IN[SLAVE1] MIDI OUT/THRU (set to THRU)
>[SLAVE2] MIDI INIn the MIDI Menu of the pedal you want to be the [MASTER], set PGM XMT to ON.
Now when you change presets on the MASTER pedal, it will also change presets on the other two pedals.
September 14, 2009 at 8:33 pm #119032
konstantine3
Memberok so if I have the TF in killdry – and the MF and PF in DSP both sets in different loops…. will the killdry still mute the other pedals?
I know nothing of MIDI but I will try this out tonight! Gotta find the two midi cables I own (thank god they are red! lol
September 15, 2009 at 3:24 pm #130134
achaput
ModeratorThe Killdry functionality should be the same as it is in your setup currently.
September 17, 2009 at 1:48 pm #130157
konstantine3
MemberWell I just ordered 2 right angled MIDI cables so Im looking forward to trying this. Get ready for a few more questions though when I go for my first attempt… These boxes are intimidating enough without the midi lol
September 18, 2009 at 8:15 pm #130171
konstantine3
MemberOne last question…..
would I still need 3 expression pedals for 3 eventide stompboxes once I Midi these things together?
September 18, 2009 at 9:41 pm #130173
As long as it does not cause a ground loop you can connect one expression pedal to all 3.
