midi sync
Home Forums Products Stompboxes midi sync
    • #112139
      beel001
      Hello
      I have one H9 and one timefactor and it's no problem to use ext sync/midiclock  to get them work together.
      But when I hook them up using "H9 app" on ipad (3:generation) the sync/midi clock dont work on the timefactor.
      (I connect H9 and timefactor with a usb cable so I can use the H9 app to controll both H9 and time factor)
      Do you understand my problem ?
      //Ben
    • #127114
      gkellum
      The MIDI DIN and the USB port are sharing one actual physical connection into the TimeFactor. So, unfortunately, you can only use one or the other.
    • #127173
      beel001
      Hello
      I want to use the aux switch to chose presets on my "TF"
      How do I set up the "parameter destination" for the aux switch ?
      Ben
