Midi Thru Funtion. Can I use that to control the TF even though I am using a DC Glass Nexus?
Home Forums Products Stompboxes Midi Thru Funtion. Can I use that to control the TF even though I am using a DC Glass Nexus?
    • #106982
      Midi Thru Funtion. I have a Midimte controlling a Glass Nexus… can I also use that to control the Timefactor via Midi through? Thanks.
    • #120210
      Your Glass Nexus appears to have an automatic MIDI Thru function – "MIDI messages sent to Glass Nexus will be echoed to the MIIDI Out jack."
      So, you can connect it's MIDI out to TF's MIDI in. Set the two devices to different receive channels if necessary.
