MIDI –> Timefactor –> Issue after V2.0.2b4
Home Forums Products Stompboxes MIDI –> Timefactor –> Issue after V2.0.2b4
Viewing 3 reply threads
    • #105546
      Mike33
      Hi
      I updated my Timefactor with the newest release V2.0.2b4 and have now the following issue.
      I switch the presets via MIDI. This works well for the first ten of presets but I can not switch presets from 11 to 20 via MIDI.
      (I activated the presets from 11 to 20 via System Menu then Utility then Bank.)
      Example: MIDI program change number 1 is preset 1:1,
                      MIDI program change number 2 is preset 1:2 etc…
      but let's say MIDI program change number 30 should be preset 15:1 or something like that, but the Timefactor does not change the preset.
      By the way. With the Modfactor this works…
      Thanks
      Michael
    • #117324
      achaput
      Hi Michael,
      I have tested this on my TimeFactor and found it to be working correctly. Have you looked at the RCV MAP menu under MIDI in System Mode? I wonder if the Presets higher than 10:2 are not assigned in your receieve map. Can you verifiy this?
      Alan
    • #117328
      Mike33
      Thanks Alan for your answer. I will check this hopefully tomorrow or then on Thursday…
      I will let you know if this was the issue.
      Michael
    • #128475
      Mike33
      Thanks Alan
      This fixed my issue.
      Regards
      Michael
