Home › Forums › Products › Stompboxes › midi troubleshooting please
July 27, 2010 at 7:53 pm #107191
discospring
Memberhi,
i'm following the instruction videos about using midi to control one 'factor with another.
i'm having no joy with any of the three things i'm trying: the clock, the exp pedal, or the general program transmit.
i've tried different midi cables and tried sending from MF to TF, and TF to MF. The only thing that's happening is the tempo of the slave becomes disabled. Any troubleshooting suggestions appreciated!
July 27, 2010 at 8:47 pm #120631
Make sure that:
1) MIDI output is set to THRU.
2) CLK IN of the 2nd is set to ON
3) CLK OUT of the 1st is set to ON
4) XMT MAP is suitably set
5) PGM XMT is set to ON
6) XMT CC (PDL) is suitably set
etc etc…
August 8, 2010 at 2:26 pm #120647
discospring
MemberThanks Nick.
I've still not any midi working. Could you have a look at my settings:
MODFACTOR > TIMEFACTOR
MIDI OUT/THRU > MIDI IN
RCV CH off omni
XMT CH 1 1
RCV CTL BYP < — BYP < —
XMT CC PDL < C15 PDL < OFF
TIP < C15 TIP < OFF
RCV MAP 0 > 1.1 etc O > 1.1 etc
XMT MAP 1.1 < 0 etc 1.1 < 0 etc
CTL XMT off off
PGM XMT on off
OUTPUT XMT THRU
CLICK IN off on
CLICK OUT on off
CLK FLT off off
August 9, 2010 at 4:47 pm #131826
achaput
ModeratorYour settings look right. Make sure a USB cable is NOT plugged in as this would disable the MIDI ports.
MIDI Clock only works on presets with Tempo ON. Do you have Tempo ON on both stompboxes?
August 9, 2010 at 6:03 pm #131828
discospring
MemberNo USB's plugged in. Tempo is on in both pedals. Makes no difference if I swop the pedal order, no MIDI is going anywhere.
Am I missing something obvious? Is it worth re-installing the software? I've never had a straight-forward update – its always been a lengthy process of crashing, freezing, then realising that it has updated but wondering if its done so properly as they never give me the thumbs-up.
