Midimoose pedal
Home Forums Products Rackmount Midimoose pedal
    • #106095
      JCOLAGROSS
      I have a Tech21 MidiMoose pedal that is phantom powered by the Tech21 PSA 1.1 that I use to control the PSA and the Eclipse. I would like to buy another Midimoose so I can use one to change the PSA and a second one to change the Eclipse(independent of each other). Will the Eclipse's midi jack phantom power the Midimoose?
    • #118349
       Alas, you will have to direct your question to Tech21 as we can't speak for them.
      Tell them that we send the signal from the pin of the power connector to DIN pin 6 and that from the barrel to DIN pin 7.
