Missing Midi
Home Forums Products Plug-Ins Missing Midi
    • #171685
      docdempster
        I have just purchased a set of plugins including blackhole etc
        am I missing something with midi. is there a way to midi up all the amazing knobs to make things a bit more manageable.
        I could only find 4 cc commands, which does not seem right.
        any help would be wonderful
        doc
      • #171690
          That is correct. Only CC messages 1-4 are mapped directly within the plug-in. You can map any parameter to the Ribbon Controller, and this allows you to assign any or many parameters to CC 1. Otherwise, you can configure the MIDI mappings in your DAW, for example, Ableton Live allows you to map a MIDI controller to any parameter.
