Missing parameter in timefactor’s looper.
Home Forums Products Stompboxes Missing parameter in timefactor’s looper.
    • #183299
      Rayzum1
        The manual says:
        “Xnob / Playback Mode: The Xnob is used to select the Playback Mode:
        [P:ONCE] – ► initiates playing the loop one time from the loop’s start point.
        [P:LOOP] – ► initiates playing the loop continuously from the loop’s start point.
        [AP:LOOP] – When recording ends, loop begins playing automatically and plays
        continuously.
        [AP:RVDIR] – When recording ends, loop begins playing automatically and plays
        continuously. In the Playing State, ► can then be used to toggle the playback
        direciton.
        The bold option doesn’t exist in my timefactor, whi is it? I’ve updated the firmware recently.
      • #183300
          Can you please elaborate? When you are using the looper and you turn the Xnob all the way clockwise, it does not display the AP:RVDIR option?
          Which firmware version is your TimeFactor on?
          If you could record a video of this and send it to support@eventide.com we can help you troubleshoot this further there.
          • #183318
            Rayzum1
              Exactly, here is a video:
              (firmware is 3.5.0 [4])
            • #183322
              Rayzum1
                I’ve found that the last version is 5.2.0 [6] and now i have the parameter. I’m sorry about this misunderstanding.
              • #183324
                  No problem, glad to hear that fixed the issue!
