Mix+ 6.4.1 Factory doesn’t quite work
Home Forums Products Plug-Ins Mix+ 6.4.1 Factory doesn’t quite work
    • #105233
      Posted by blackmacdaddy
      First off, I love the plugs! (and like most hope there will someday be a RTAS version)
      I’m on MIX 6.4.1cs4 & 10.3.9 and while I know that Reverb, Quad & Octa are not MIX compatible, Factory is listed as “compatible.”
      However, whenever I try to insert it, I get:
      “There was an error loading the plug in” (Pro Tools dialog)
      The plug then loads and appears, however:
      The input & output meters are “feeding back” internally
      and I can’t pass any audio.
      Any help, such as changing the loading order of the plugs via renaming or other “tricks” etc, are very much appreciated.
      Thus far I have tried un-installing and re-installing and trashing my DAE prefs. Neither action worked
      Thanks to all reading,
      All the best,
      Walt
    • #116733
      Posted by Dan
      We have recently discovered a problem with one of our Anthology II releases regarding Factory on Mix. To determine if this is the problem please contact D. Rooney at DRooney (at) eventide (dot) com.
      Thanks,
      Dan
