Home › Forums › Products › Stompboxes › Mix control
August 23, 2010 at 5:41 pm #107229
JNPMusic
MemberI'm having an issue with my TF . It seems like I'm losing the direct signal too early. Maybe I'm running it the wrong way but all my mixes seem to be between 5-10 and any thing over that starts to drown out the direct signal. Running it in the effects loop.
August 23, 2010 at 6:07 pm #120695
Make sure KILLDRY is off, and MIX is high.
Otherwise, contact support@eventide.com, giving your software version number and more information as to how the TF is connected, along with a better description of the problem.
August 23, 2010 at 6:11 pm #120696
JNPMusic
MemberHi,
Yes killdry is off but what do you mean by mix is high?
Thanks for the reply…
JP
August 23, 2010 at 6:42 pm #131882
Sorry to be unclear – I meant the MIX knob, top left.
August 23, 2010 at 6:49 pm #131883
JNPMusic
MemberBut that's my problem. If I turn the mix control up over 10-15% I start to lose the direct sound. It would be nice if it would have a less gradual mix since it goes to 100% anything over 15 and my mix gets to wet.
August 23, 2010 at 7:52 pm #131885
achaput
ModeratorHi there,
Is your amp's effects loop a parallel or series type? Some amps have a switch that lets you choose either way, while other amps are hardwired one way or the other.
August 23, 2010 at 8:00 pm #131886
JNPMusic
MemberIt's a series loop with controls. Mesa/Stiletto.
August 23, 2010 at 9:54 pm #131888
achaput
ModeratorOK, with a series loop the amp can compress the wet and dry signal together depending on how much gain you use and how much power tube saturation takes place. The more compression that occurs, the less range will be audible between dry and wet on the mix knob. One way to overcome this is to use another amp for the wet effects, ie a wet/dry setup.
In your setup now, as long as it sounds the way you want there's no need to worry about how low the mix knob values are.
August 23, 2010 at 10:01 pm #131890
JNPMusic
MemberOK, That sounds good… It doesn't sound bad at all, it just seemed odd that the mix would be set that Low and I thought there might be something I'm doing wrong…..
Thanks for the help!
JP
