Mix resets to full dry on MIDI clock start
Home Forums Products Stompboxes Mix resets to full dry on MIDI clock start
Viewing 3 reply threads
    • #115859
      SpaceRock74
      Hi
      I have Time Factor and Space, slaved off a MIDI master. When the clock starts the mix resets to full dry (on both units), and I have to turn the mix knob to re-engage the effect. Is there a setting to change this?
      Thanks
    • #154563
      bohan
      SpaceRock74 wrote:
      Hi
      Thanks
      Are you sure you are not sending any MIDI CC messages? You can try turning off the MIDI CC mappings for the Mix knob on both units.
    • #154569
      SpaceRock74
      Ok, I set MIDI receive channel to OFF in the Timefactory and it now behaves the way I want it to. MIDI clock still works.
      Thank you
    • #154571
      camn
      OMG SOMEONE USED A RATIONAL APPROACH TO TROUBLESHOOTING I COULD CRY WITH JOY
    • #154564
      SpaceRock74
      bohan wrote:
      SpaceRock74 wrote:
      Hi
      Thanks
      Thanks for the quick response. The Drumbrute which I use as MIDI clock source has default settings and is sending this on start –
      53837,112.1625,24:0,,Start,,,
      53837,112.1657,24:0,,Clock,,,
      53838,112.1684,24:0,2,Control change,54,127,
      53838,112.1708,24:0,-,System exclusive,6,,f0 7f 7f 06 02 f7
      53839,112.2245,24:0,10,Note on,42,100,
      53847,112.2271,24:0,,Clock,,,
      53852,112.2295,24:0,10,Note off,42,0,
      53857,112.2321,24:0,,Clock,,,
      53867,112.2346,24:0,,Clock,,,
      53877,112.2891,24:0,,Clock,,,
      53887,112.2918,24:0,,Clock,,,
      53896,112.2943,24:0,,Clock,,,
      53897,112.2969,24:0,2,Control change,54,0,
      53906,112.3533,24:0,,Clock,,,
      53916,112.3559,24:0,,Clock,,,
      53926,112.3584,24:0,,Clock,,,
      53936,112.4123,24:0,,Clock,,,
      I will investigate the meaning of these CC messages.
    • #154567
      bohan
      Yean, it looks like it triggers some MIDI CC messages that might be mapped to some parameters.
