Home › Forums › Products › Stompboxes › Mixing link DI/line out hiss
- This topic has 2 replies, 2 voices, and was last updated 1 year, 10 months ago by
Realbrass.
July 8, 2020 at 1:40 pm #115997
Hi.
I have a Mixing link set up on a pedadlboard using it with a clip on mic to run through some pedals and usually using DI or line out to a PA.
But there seemes to be a lot of hiss coming through the DI out. If I have the dip at DI an connect to a mixing board via XLR to a Mic level channel I get a lot of hiss sound.
And it dosen’t matter if anything is connected or not, all gains to zero and the input knob at -20db , this seemes to be a general hiss on the output.
This is a fairly new unit, about a year old and has always been sitting on my pedalboard, in a case.
Is this an issue you are aware of, are there faulty units around ? This is unusable like that.
the serial nr. is MX-03603
January 23, 2023 at 7:40 pm #168595
Me too. Have you found a solution?Just got a Brand new mixing link today. There is a lot of hiss. I’m just testing. Sm58, I disconnected the effects so just the microphone to the unit off to a DL32/M32c. gain on mixing link off. (doesn’t matter though, doesn’t get louder or lower with any knob or button on the mixing link just a lot of hiss. when plugged in. I plug the mic directly into the DL32/M32 completely quiet. I really need this unit so we can do a specific effect B4 the m32 as that is just our IEM and then it goes to a split to FOH, so the effect has to be b4 everything. But now it looks like I’ll have to use a separate input, and mic for this one part in one song as I can’t have this hiss on the lead vox the whole night. What a Pain. Does anyone know if the radial Voco-Loco has hiss?
June 19, 2023 at 6:16 pm #172014
I too am having excessive hiss issues with the mixing link. Using a DPA mic to XLR mic input with phantom, DI/Line out to the desk with LINE selected on the bottom of the box there is this incessant excessive hiss/noise. I have tried every imaginable permutation of gain adjustment/different lead/pad settings on the desk etc and still the same. Even worse, when the FX loop switch is toggled to on it doubles the hiss/noise whether or not anything is connected to it! Can anyone please help me? I have been tolerating this for months but really need to make this a useable device which at the moment it just isn’t. I really hope I am doing something wrong, please advise.
FYI:
Settings: Input Gain LOW (and dial on zero)
DI/LINE: LINE
GND/Lift: GND
One interesting (but worrying) note: if I set the mix selector switch to MIX and engage the FX LOOP button to ON and I touch the metal mix selector switch there is a really loud hum, the kind you get with a bad earth. Could this simply be a faulty box?!
Thanks
