MixingLink Hum when touching “MIX MODE Toggle Switch”
Home Forums Products Stompboxes MixingLink Hum when touching “MIX MODE Toggle Switch”
Viewing 5 reply threads
    • #116611
      Hi, when the FX-Loop on my MixingLink is engaged there is a hum/buzzing sound, as soon as I touch the Mix Mode toggle switch. When touching the other metal parts there’s no problem. Also this apparently only occurs when nothing is plugged into the DI/Line out. Is this normal, or is there something wrong with the grounding? Any help/suggestions?
      Regards
      Tom
    • #158401
      Stax_911
      • #158412
        JWaltz
          Hi Tom,
          Does it help if toggle the gnd lift switch
          Joe Waltz, Eventide
        • #158414
          I already tried that. Doesn’t help unfortunately
        • #158415
          JWaltz
            Hi Tom,
            What is your MxLnk ser#? Can you email this to support@eventide.com and we’ll get back to you about repair/replacement.
            Thanks, Joe
          • #158424
            Hi, the serial number is MX-04256 (Model: 1183-000). I purchased it at Thomann Germany and their warranty is still valid so I’ll probably return it through their service.
            Thank you for the help!
