Home › Forums › Products › Stompboxes › MixingLink & iPhone Effect App
July 25, 2016 at 12:49 pm #113594
MIC to Mic IN
AUX Phonejack Use TRRS Connector Iphone & MixlingLink
DI Out to PA
Play Music on MixingLink Is OK, But Can’t hear Effect App Return Sound!
where mistakes?
July 26, 2016 at 1:37 pm #143930
You use the good four conductor (TRRS) mini phone jack so it should work.
I am very interested by your problem because i’d like to make the same install with my mixing link and my ipad.
So any suggestion from Eventide ?
Thanks
July 26, 2016 at 5:18 pm #143932I Already Used TRRS Line …They Said They don’t claim Apple headphone jack compatibility for sending audio to iOS device……..But Good Effect App is usually only iOS system…I Guess….issue is MAC Device Pin 3 Is ground & Pin 4 is Mic, But Usually Pin 3 is Mic!but I’m not Sure. and don’t Know How To fix it!
July 26, 2016 at 7:31 pm #143934
Do you have the possibility to try with a regular TRRS connector (with mic in the mic on the pin 3) ?
Where did you see that the Apple TRRS jack was not compatible ?
July 26, 2016 at 10:28 pm #143937
Please dear Eventide techs can you answer to this very interesting question : is it possible to use an ipad or an iphone as a source of effect with the Mixing link ?
I read that it is possible in several specialised website before bying my Mixing link. (here for example : http://www.musicradar.com/reviews/guitars/eventide-mixinglink-608453)
And this schema on your website show that it’s possible to plug an ipad type device to have an in+out connectivity to the mobile device using a four-conductor 1/8 TRRS cable.
Thank you for your insight.
July 27, 2016 at 1:12 am #143938
Apple TRRS jack was not compatible info is from eventide customer service.
i’m not eventide engineer. I just guess MixingLink Aux phonejack pin3 is mic, but in ios device mic signal in pin4, so if use regular trrs line link mixinglink & IOS device, maybe have some phase issue.
July 27, 2016 at 2:49 pm #143943
Maybe you could try an adapter converter like this one :
It’s done to convert the Apple headphone system (OMTP protocol) with other stuff using CTIA protocol (Sony, Motorola, LG… and maybe also Eventide Mixing Link). It resolve the problem of Ground and Mic.
Please someone from Eventide can confirm that this type of converter could do the job ?
Thank you.
September 11, 2016 at 1:27 pm #144347
Is it possible to know which TRRS cable we have to use to connect the Mixing Link Aux to an iphone or ipad ?
For exemple if we use this style of adaptator will it work ? http://www.ebay.com.au/itm/SONY-CTIA-to-OMTP-Adapter-Converter-Cable-for…
Thank you.
September 11, 2016 at 5:39 pm #144350
To Stax_11
Eventide did not get Apple Approval for support of iPhone/iPad head/mic jack with the MXLNK AUX jack.
Currently there is no work-around for direct interfacing to iOS devices.
Sincerely
joe waltz
eventide
October 1, 2016 at 6:37 am #144523
Would the Lightning to 3.5mm adaptor make any difference? It is just an idea.
October 1, 2016 at 8:39 pm #144529
Hey, that is a good idea! I will try that 'lighting to 3.5mm' adapter and let you. thx
joe waltz
eventide
October 21, 2016 at 1:38 am #144684
Hey this cable works for me. I am using IOS guitar apps ( AmpliTube, Cubasis, GBand, Ampkit) with Mixing link. Can be noisy at times. Never tried it with a mic
https://www.amazon.com/iSound-ISOUND-6378-Audio-Devices-Output/dp/B013HJWE6S
October 26, 2016 at 5:54 pm #144739
I tried this and I can't get it to work reliable with various apps and devices with iOS 10.
So that being said, Eventide does not support MXLNK using the AUX connecter as an IOS interface
joe waltz
eventide
October 27, 2016 at 6:02 pm #144749jwaltz wrote:
I tried this and I can’t get it to work reliable with various apps and devices with iOS 10.
joe waltz
eventide
Too bad. Thank you for trying it out though!
January 26, 2017 at 10:09 am #145586
Hi just wanted to check if this is now possible?
… to Connect iphone or iPad To the aux connector via lightning port?
