MixingLink: Two Mono inputs at Instrument IN?
Home Forums Products Stompboxes MixingLink: Two Mono inputs at Instrument IN?
    • #163085
      mmryspace
      I am using my MixingLink’s Instrument IN as part of the FX chain for my Boss BX-800 Mixer:
      Mixer FX SEND -> ML INST IN
      ML DI/LINE OUT -> Mixer FX RETURN
      ML TO FX and FROM FX –> FX PEDALBOARD
      Can I use a  TS MONO Y splitter like the one pictured at the ML INST IN and have both the FX Send and Guitar Input simultaneously?
      YPP-111_Full_RGB_1800
    • #163113
      Using the Y-Splitter is not ideal for this configuration. Why not plug the guitar directly into one of the channels mixer instead of plugging it into the MixingLink?
      Alternatively, you could try:
      Mixer FX SEND -> ML MIC/LINE in
      Guitar -> ML INST IN
      The input gain will apply to both the MIC/LINE in and INST IN simultaneously so you’ll have to set the level of your sources accordingly, but this would be a better configuration than using a splitter to sum 2 sources to the INST IN.
