MixingLink with Guitar FX Pedal Board & Rack FX?
Home Forums Products Stompboxes MixingLink with Guitar FX Pedal Board & Rack FX?
    • #151129
      bohan
      mmryspace wrote:
      My question is where in the signal path do I put the Lexicon MX200 and how for best results? The Lexicon has a L/R input and an L/R output but I am unsure where the Lexicon MX200 should go in relation to the MixingLink, my mixer, audio interface, and the FX pedalboard. Any technical advice and suggestions would be super helpful. Thanks!
      I would suggest MixingLink's Line out -> MX200 -> Mixer's FX return -> audio interface
      • #151133
        mmryspace
        bohan wrote:
        I would suggest MixingLink’s Line out -> MX200 -> Mixer’s FX return -> audio interface
        Thanks so much for the reply. Apologies for my confusion. Your post reply in the forum is different than the one I received by email. In the email it says:
        “I would suggest Mixer’s FX send -> MixingLink’s Line out -> MX200 -> Mixer’s FX return -> audio interface”
        and in the forum here it says: “I would suggest MixingLink’s Line out -> MX200 -> Mixer’s FX return -> audio interface”.
        Could you please clarify the appropriate suggestion? Thanks so much!
      • #151139
        bohan
        mmryspace wrote:
        Thanks so much for the reply. Apologies for my confusion. Your post reply in the forum is different than the one I received by email. Could you please clarify the appropriate suggestion? Thanks so much!
        Oh, sorry for the confusion. That's because I edited my post. I was worried that you might misunderstand my suggestion so I deleted "Mixer FX Send ->". I'm happy that works out well for you.
    • #115177
      mmryspace
      I recently purchased a MixingLink specifically for the purpose of using my guitar FX pedals with various synthesizers in my home studio for the MixingLink’s impedance matching capabilities. Additionally, I have a Lexicon MX200 FX processor rack that I would also like to incorporate into my setup. My question is in regards to the signal path and how to incorporate the Lexicon MX200.
      I have been able to successfully (though not sure correctly?) use the MixingLink with my guitar FX pedal board by using the MixingLink’s To/From FX connections and using the INST IN & DI LINE OUT connections with my Boss BX-800 Mixer’s FX Send/ Return. The Boss mixer’s main outputs then run into my Behringer U-PHORIA UMC404HD audio interface and into my DAW.
    • #151136
      mmryspace
      Thank you for clarifying – works perfectly!
