Modfactor bypass: DSP+FX
Home Forums Products Stompboxes Modfactor bypass: DSP+FX
Viewing 9 reply threads
    • #106935
      Will you be adding DSP+FX bypass on next release.  It would be useful with Undualtor patches with long trails.  You could turn the effect to bypass and still hear trails while playing over said trails, that would sound pretty cool intead of just cutting of trails when switching to bypass.  Maybe have spillover too when switching between presets.
      Thanks,
      A
    • #120133
      Anyone want to take a stab at this, or are there any MF owners that would find this useful (just curious).
      Thanks,
      A
    • #120140
      Of course!  I haven't played around with the undulator much, but I guess I assumed that it would default to continuing when switched to bypass or a different effect.
    • #120141
      I just started programming patches with my MF and TF and ran into the same problem.
      I really need some spillover with the undulator.  I was very disappointed after searching for the spillover control in vain.
      The sounds are great in the MF, but we need a mix control also.  Intensity doesn't blend the dry signal as a mix could.
    • #131320
      I just wanted to say that although I do really want the features that I request, I have no idea how difficult it may or may not be to add these functions to the MF.  I am blessed that I even have to the opportunity to request such features.  A lot has changed in my thirty years of playing. Beer
    • #131322
        Sorry guys – it's hard to add spillover to a modulation effect. It essentially requires a copy of each effect running at the same time, which halves the resources available.
        Essentially you have a choice between lesser effects with spillover, or greater effects without. Rightly or wrongly, we chose the second.
      • #131323
        I can understand the spillover limitations and agree it is better to have greater effects without spillover.  I was really interested in the Bypass+FX for use with Undualtor patches, do the same limitations apply?  You could get some great dynamics letting Undualtor trail off while playing lets say an overdriven riff over it.
        Thanks,
        Anthony
      • #131325
          Bypass+FX is feasible because you don't have to have a second effect running during the fadeout, so my previous comments don't apply. I'll add it to the list….
        • #131327
          Duh!  (Slap self in forehead!)  But Undulator spillover when switched to bypass is also a "duh!"  Thanks!
          (Hmmm… This does point to a future Modfactor2 with double the hardware resources – 2 effects simultaneously, effect-to-effect spillover….  Arrrgh!  More wallet damage!)
        • #131328
            But then people will want two simultaneous effects, each with spillover on preset change, requiring 3/4 effects, etc, etc…
