Modfactor – Expression pedal confuzzlement!
Home Forums Products Stompboxes Modfactor – Expression pedal confuzzlement!
    • #107048
      sonson_prest
      I've got a strange thing happening wit' me pedal!
      I decided to change the pot of my expression pedal since the previous one was crud – it's the same type – 22k linear.  Installed and it works…backwards…  I swapped the polarity of the pot and still exactly the same problem.  I use the expression pedal as the waveshape adjuster, not as a parameter adjuster so to speak.
      Is there any way to make the modfactor 'see' the expression pedal backwards?
    • #120333
      It sounds like an electrical problem at your end.
      But, it is possible to set up the pedal so that maximum and minimum are reversed – you would have to do this on a knob by knob and preset by preset basis – tedious. There is no global setting.
