Hi, i've got a little problem, i want to use the wah effect with an expression pedal but i' ve noticed that the pedal when hooked up will affect any other preset, what i'm asking is this.
Is it possible to create a preset with the expression pedal on and when i switch to the second preset have the expression pedal off without affecting any parameter?
My expression pedal is a Bespeco vm19l , it's like roland ev 5 more or less.
Last thing, in your expression pedal video tutorial number 4 you use a stereo cable, my modfactor seems to work only with a mono, is it ok?
Thank' s a lot for your help
