Home › Forums › Products › Stompboxes › Modfactor / H9 Flanger – TZF sounds?
Does anyone have a Flanger setting that would approximate the TZF / Eric Johnson High Landron's sound?
Here's a start:
Expression Pedal Heel DEPTH 65
Expression Pedal Heel SPEED 0.15 Hz.
Expression Pedal Heel MODIFY DLY O/P 35
Expression Pedal Toe DEPTH 50
Expression Pedal Toe SPEED 0.25 Hz.
Expression Pedal Toe MODIFY DLY O/P 75
Thanks very much for sharing!!
Cheers!
I’ve read in an interview where he said he was using two MXR flanger units to cancel each other out.
