Modfactor in loop with Boss LS 2
Home Forums Products Stompboxes Modfactor in loop with Boss LS 2
    • #111919
      My modfactor is isolated on a Boss LS2, Killdry on. I blend the mix of the clean guitar with the modulated guitar to get the sound I want …
      Should I use the Amp level or the Line level on the modfactor ?
    • #126686
        Hard for us to know (too many possibilities). Try guitar first – if this distorts, use line.
      • #126687
        I tried line, I get a slight boost of volume and no difference in sound. Actually I'd say I can hear modulation better …
        I have to say that using a looper pedal with the possibility to blend dry wet with the guitar signal, placing the modfactor before od's & distortion in killdry mode has transfigured the pedal.
        If it can be from any help to anyone outthere, I don't have to make a couple of preset anymore like a chorus for clean and the same chorus for distortions or overdrive with a different intensity. Sounds are much more balanced and the blend is just around 50/50.
        I wish it would just be a little less coloured / more transparent by the stompbox in the low freq range. You just loose a bit of precision and tone of the pickup for some mods.
