Modfactor Jeft flanger – Lenny K Are you gonna go my way
Home › Forums › Products › Stompboxes › Modfactor Jeft flanger – Lenny K Are you gonna go my way
    • #109556
      msurry
        Hi just got myself a modfactor and trying to find the same 'jet flanger' sound that is at the start of the solo in Lenny K are you gonna go my way. The preset isnt that close.
        Anyone got that sound close?
        Cheers.
        Mike
      • #124261
        madeski
          Use the thru zero flanger and plug your output to the right channel instead of the left one (which is the mono one if I remember right) play with the depth knob and at the peak of the sweep your sound should cancel all the way out. I use it this way in my band and it sounds killer.
        • #124271
          msurry
            THanks for the reply. Im using the modfactor then timefactor in an effects loop so not sure what you mean with input / output set up?
            Do you use the 'Thru 0' type rather than Jet? Id always thought it was a jet typeflanger. So many options and settings its a job to keep it simple!
            Thanks again.
