ModFactor Midi Help?
Home › Forums › Products › Stompboxes › ModFactor Midi Help?
    • #108422
      I'm running a Strymon TimeLine Midi to the ModFactor. I have saved all presets and done everything I want, but  I don't want when I switch presets and choose a different delay for the ModFactor to active the sound for the preset. Can anyone help?
      I want the ModFactor to switch but no activate the preset that it has stored for when I just want the delay. I want to activate the ModFactor effect myself.
    • #123136
      achaput
        You could try this-
        Save a preset with intensity all the way off in a :1 slot. Save your preset in a :2 slot. When you send a MIDI program change, select the first preset, which essentially has no effect. (Similar to DSP Bypass.) Then when you want to activate your effect press the Middle Footswitch to load the :2 preset.
