Modfactor Output Levels..
Home Forums Products Stompboxes Modfactor Output Levels..
Viewing 3 reply threads
    • #112811
      Hi all.  I’ve picked up a Modfactor pedal to go with my TF and have noticed that the thing changes output level in a a big way depending on algo.. selecting chorus for example seems to lift the ouput level significantly.. is this normal?
    • #140369
      I don’t have a Modfactor but it does happens with the algorithms I have in my H9.
      Same case for Pitchfactor.
    • #140398
      st.bede
        Now that I can adjust the out per preset, I do not worry about that any more. There has been great support from Eventide for the pedals.  🙂
      • #140399
        wedelich
          grappagreen wrote:
          Hi all.  I've picked up a Modfactor pedal to go with my TF and have noticed that the thing changes output level in a a big way depending on algo.. selecting chorus for example seems to lift the ouput level significantly.. is this normal?
          This is normal, and as st. bede stated, our solution to this issue was to add output level control per preset.  If even the output level adjustment doesn't contain the volume swings for you, there may be an issue.  But I'm pretty confident it should work.
