Modfactor question
Home Forums Products Stompboxes Modfactor question
    • #108880
      Jasonplays
      With the MIDI CLOCK OUT set to ON, OUTPUT set to XMT and Global tempo OFF – Does the Modfactor send the same MIDI CLOCK OUT tempo regardless, until the tap tempo is adjusted. This is what mine is doing (500ms). Is there a way to turn it off and on while playing as mine is always transmitting a the same tempo regardless (with MIDI CLOCK OUT set to on). I realise that if you want Global Tempo but still have presets which ignore the global tempo value, save those presets with Tempo OFF. Can this also be done with the MIDI Clock out as I want other units to ignore this from time to time.
      regards
      Jason
    • #123589
      achaput
      To change the tempo of MIDI Clock OUT you have to turn Tempo ON. Presets can be saved either with Tempo ON of OFF. Global Tempo means that the saved tempo of the Preset will be ignored, and the tempo transmitted will be the last tapped-in value. (Tempo still must be turned ON.)
