Modfactor – stereo modulation query
Home › Forums › Products › Stompboxes › Modfactor – stereo modulation query
    • #111029
      kevinattics
        So, many modulation effects (chorus, phaser, flanger) rely on splitting a mono signal and playing with its time. Does the modfactor operate in true stereo for these effects (I.e. is one channel dry while the other is affected?). If I put the phaser effect on with two outputs, for instance, is the phase on both channels or do I have to listen to them together to create the experience?
      • #124672
        achaput
          The ModFactor's effects are True Stereo, however one side is not dry. Instead, the effects get spread across the stereo signal. If you want one side to remain dry, you could do this by running your instrument through a splitter and send one output from the splitter into ModFactor and another output from the splitter directly into an amp.
          Alan
