Home › Forums › Products › Stompboxes › Modfactor with bluetooth
January 7, 2016 at 2:31 pm #113150
Trendin
ParticipantHi, is there a way to connect some usb-b to bluetooth adapter tp modfactor so i could connect it wirelessly to my pc?
January 7, 2016 at 2:32 pm #142071
gkellum
ParticipantTrendin wrote:Hi, is there a way to connect some usb-b to bluetooth adapter tp modfactor so i could connect it wirelessly to my pc?
ModFactor doesn't have a Bluetooth chip in it. You can do that with the H9 though which does have a Bluetooth chip in it.
January 7, 2016 at 2:37 pm #142072
Trendin
Participantgkellum wrote:Trendin wrote:Hi, is there a way to connect some usb-b to bluetooth adapter tp modfactor so i could connect it wirelessly to my pc?
ModFactor doesn’t have a Bluetooth chip in it. You can do that with the H9 though which does have a Bluetooth chip in it.
I know and that’s not what i asked.
I want to connect a usb to blueooth connector to modfactor so it could have bluetooth capabilties. Is this possible?
January 7, 2016 at 2:52 pm #142074
gkellum
ParticipantTrendin wrote:I want to connect a usb to blueooth connector to modfactor so it could have bluetooth capabilties. Is this possible?
The ModFactor has a USB slave jack. Bluetooth USB dongles need a USB master jack. So, as you're describing it, this won't work.
For this to work, you would need some sort of wireless MIDI device that connects to the ModFactor directly over MIDI and connects to your computer wirelessly in some fashion. If you do some online research, you might be able to find something that does this. The solutions I know of are all geared to use with iOS devices; I don't know of anything offhand that will meet your needs.
January 7, 2016 at 2:54 pm #142075
Trendin
ParticipantI see 🙁
Thanks for the quick reply.
March 11, 2016 at 11:13 am #142853
holty
MemberThats a shame that its not possible. I’d like to connect my two MF & TFs to my ipad without the wires. Is there any options if you use a usd hub with bluetooth connections?
