Modul “mix” realtime Control Crackle Help!
Home Forums Products Rackmount Modul “mix” realtime Control Crackle Help!
Viewing 3 reply threads
    • #107217
      MFPhouse
      i just want to control the first Input from the Mix Modul (the simple mixer two in one out ) via the Pedal 2.
      Knob is set ….everthing works…except i get also i crackle while changing the value.
      I tryed already other resultions and other knops…….but still the same.
      Any idear anyone?
      or did i need an other modul?
      I just want to build up an "Input Delay"..so i want to control the Input of the Delay.
    • #120670
      achaput
      Try using a c_fltr_a module into a multiply module to smoothly control the level.
    • #120683
      MFPhouse
      Great ! Works! Thank you
      BTW : Questions like this better here or in the Vsig Forum or is this still the same?
    • #131913
      achaput
      Glad it helped. More Vsig users would probably be able to help you with this type of question in the Vsig forum.
