November 28, 2010 at 2:37 am #107408add123Participant
hi there
i am receiving my serge modular panels any day now, i am wondering if is it ok to plug a modular like that directly into the analog input of the h8000 ?
i know the signal from the serge is very strong, but i would like to treat the synth like how guitarists work with the eventides.
many thanks
November 29, 2010 at 3:11 pm #121051Doug WellingtonMember
add123:
Congratulations! As I often say, "Once you start down the modular path, forever will it dominate your destiny!" I haven't updated it in a while, but I have a web page about modular stuff at analognotes.com
I have a decent sized MOTM and Blacet modular myself. The output is indeed very hot. I always use a mult/attenuator between the modular and my H8000FW…
January 9, 2011 at 10:26 pm #121355AndyScoresFilmMember
Same thing for a Moog Slim Phatty going into the H8000FW? A preamp in-between?
January 10, 2011 at 5:01 pm #121361
The H8000 analog inputs will handle over +24dBU, this is almost 15V peak to peak. My guess is that the output of the modular synth is probably less than this, so a direct connection will be fine.
January 11, 2011 at 6:05 am #121371AndyScoresFilmMember
A few more (silly) questions…
What about a vocal mic or a guitar?
Should they go into a preamp first prior to the H8000FW? What would the advantages/disadvantages be without the preamp?
January 11, 2011 at 4:43 pm #132546
A mike will need a preamp to get enough level.
A guitar can be connected directly to the 1/4" sockets, but you will probably need to crank up the input gain.
