modulation speed?
Home Forums Products Rackmount modulation speed?
    • #110942
      wilkinsi
      I can modulate anything I want (within reason), but want to set the SPEED at which the parameter is modulated. For example, if I want to modulate the SIZE within the DIFFUSER of DIFFCHORUS, I can do that, but I want to slow the modulation speed, to create the same effect as turning the knob on the Space pedal (can be heard on plenty of Eventide intro jingles). I no longer have a Space, and only want the modulation to be automatic rather than manual. I don't recall seeing such an option. Should I be accessing SETUP or just the modulated parameter, or is the option simply not there?
    • #124496
      wilkinsi
      DUH! Its in <EDIT MOD>. I just need it to sound as smooth as the Eventide demo. Any suggestions as to duplicate that swishy part of the demo?
