moving saved programs back to TimeFactor ???
Home Forums Products Stompboxes moving saved programs back to TimeFactor ???
Viewing 8 reply threads
    • #107186
      J.Paul
        I've saved a  bunch of Time Factor patches (programs) with a Sysex program on my Mac. Now I want to move them back onto the Time Factor. What is this called ? a transfer? a dump?What is it technically called in the manual?
        thanks
      • #120622
          In the manual it is called a dump.
        • #120623
          achaput
            To send presets back into your Factor pedal you need to perform a System Exclusive Data Dump, or "Sysex Dump" from your computer to the pedal. TimeFactor is always ready to receive a dump; you just have to initiate it from the computer.
            By the way, the easiest way to backup Factor Pedal presets is with Eventide's Factorlib program for Windows or Mac.
          • #120624
            J.Paul
              thanks for the replys
              achaput:
              …………………. TimeFactor is always ready to receive a dump; you just have to initiate it from the computer.
              yeah, so you're saying that a dump goes both ways?It's a dump when you save and a dump when you restore?
              the manual didn't specify that part
              page 26 (of the manual) says that "dumping" is saving or backing up the sounds (I've already got that part)….
              so the part I need (I think) would come in the next section of the manual called "restoring presets and system settings….which basically says for us to choose a Sysex ID and exit; but never says to initiate it from my computer (or FactorLib). This worked for me….wish it had been clearer in the manual.
            • #155678
              bluedaniel714
                “so the part I need (I think) would come in the next section of the manual called “restoring presets and system settings….which basically says for us to choose a Sysex ID and exit”.
                none of this makes any sense to me.  i read that part in the manual and it tells me nothing.  i backed up my presets as instructed before i installed a software update via Direct Uploader.  I’m glad it made it so easy to backup – too bad it doesn’t  prompt a re-install.  my Timefactor is hooked to my computer with USB cable.  can i get these presets back on my Timefactor? i don’t use H9 whatever that is.  i tried using Direct Uploader via “update from file” but that didn’t work.  i searched the manuals and forums – this is the closest i’ve got.  Please help.
              • #155682
                bluedaniel714
                  I certainly wish that were true.  but it’s not.  all my custom presets are gone.  any help with getting them back?
                • #155684
                  bluedaniel714
                    sorry to be so difficult i’m not that tech savvy.  i just tried to Add a new file Attachment on the thread and i got a message: txt, png, jpg, gif, h9z, json, tide, pdf, 9kp, 9kf, 9ks.
                    the backup file is “.syx”.  is there something i’m doing wrong?
                  • #155699
                    bluedaniel714
                      k.  don’t laugh there are only 4 banks of 2 presets. mostly different versions of the same delay.  but i’ve become very comfortable with using them 🙂
                      https://drive.google.com/file/d/1yHpNaUkq4g2itx8y9YXcbiq6gD-nQkoC/view?usp=sharing
                    • #155815
                      bluedaniel714
                        Thanks for your help.  It forced me to download and use the H9 Control app.  Turns out it’s super easy to learn and I love it.
                      • #155681
                        bohan
                          bluedaniel714 wrote:
                          "so the part I need (I think) would come in the next section of the manual called "restoring presets and system settings….which basically says for us to choose a Sysex ID and exit".
                          none of this makes any sense to me.  i read that part in the manual and it tells me nothing.  i backed up my presets as instructed before i installed a software update via Direct Uploader.  I'm glad it made it so easy to backup – too bad it doesn't  prompt a re-install.  my Timefactor is hooked to my computer with USB cable.  can i get these presets back on my Timefactor? i don't use H9 whatever that is.  i tried using Direct Uploader via "update from file" but that didn't work.  i searched the manuals and forums – this is the closest i've got.  Please help.
                          You don't need to reinstall presets because the presets are not changed or affected by the software update. The previous presets should still be there. You can use H9 Control to easily manage and export/import presets for your TimeFactor.
                        • #155683
                          bohan
                            I certainly wish that were true.  but it's not.  all my custom presets are gone.  any help with getting them back?
                            Could you share your presets backup here?
                          • #155698
                            bohan
                              sorry to be so difficult i'm not that tech savvy.  i just tried to Add a new file Attachment on the thread and i got a message: txt, png, jpg, gif, h9z, json, tide, pdf, 9kp, 9kf, 9ks.
                              the backup file is ".syx".  is there something i'm doing wrong?
                              Try Google drive?
                            • #155729
                              bohan
                                k.  don't laugh there are only 4 banks of 2 presets. mostly different versions of the same delay.  but i've become very comfortable with using them 🙂
                                OK. I downloaded your backup file and dragged it into H9 Control. All presets are imported correctly. See my attachment.
                              • #155821
                                bohan
                                  Thanks for your help.  It forced me to download and use the H9 Control app.  Turns out it's super easy to learn and I love it.
                                  You're welcome. I'm glad that worked out well for you.
