March 1, 2012 at 4:24 pm #108467
pinot
MemberHi, I use an Alesis Quadraverb with Echoes from the Past (programmed by Charlie Hall) for old Shadows songs which use multi-head echoes (Echomatic I and II, Binson) intensiv. Now I consider to replace by Eclipse. I studied the manual but I am overstrained to program that myself. Has anyone done that already and has some experience how to go on?
Kind regards Pinot
April 3, 2012 at 9:17 am #123278
NiCKEL
ParticipantUh, I do have an Eclipse and I'm in need of multi head tape delays, too. But I'm lucky enough that I only need to replicate the early Mr. Gilmours' sounds (Binson Echorec II), who didn't use the multi head thing as extensively as Marvin did…
I have figuered two approaches but need to test them when I have time…
1. Using the TF TapeEcho (#817), followed by the mono looper at 0ms (only to make it mono). That way I think I can replicate the sound of two recording heads good enough, so I could cover those Gilmour stuff.
2. Again using the TF TapeEcho (#817), this time followed by a digital multi delay. In this scenario I would use the TapeEcho to get the flavor only and not for the actual repeats. I would try to get all the repeats needed with that following multi delay, with only little additional modulation.
I think the results, while not perfect, but could turn out way useful…
When it comes to multi head tape delays, even the latest and most powerful delay pedals (Strymon TimeLine, Empress Vintage Modified Super Delay) just don't deliver… I can't believe how Strymon ditched that function when they cramped the ElCapistano into the TimeLine…
It would be nice to have more influence on the panning of the TF presets or on the presets in general. Perhaps the [LEVEL] section of the programs would be a good place for additional panning aid with a future update..?
[FXA MIX] [FXA LVL] [FXB MIX] [FXB LVL] > next page [FXA PAN] [FXB PAN]
I'm not a specialist here, but that way the actual preset algorithms wouldn't need to be touched and it would be of INCREDIBLE help in many situations..?Cheers
April 3, 2012 at 12:37 pm #123280
NiCKEL
ParticipantWell, I do have an Eclipse and I also need multi head tape delay some time soon, to cover some early David Gilmour sounds (Binson Echorec II). But I'm lucky enough that Gilmour didn't use that many variations on that stuff as Marvin did, so I guess I will be fine with two head sounds…
I have figured two approaches that could work but still need to be tested…
1. Using TF TapeEcho (#817), followed by a mono looper at 0ms (just to make the dual delay output mono). This would give me the two heads that I need 🙂
2. Again using TF TapeEcho, but for more complex tappy stuff (Marvin is known for) this time followed by a clean multi delay. In this scenario the TapeEcho would provide the coloration only but not the repeats. The multi delay would simulate the multiple heads and I guess there wouldn't be much more additional modulation required.
Still not perfect… the feedback path wouldn't be simulated accurately… but there are chances it could work out.
Somehow it's hard to understand why no company would make a handy unit that can handle both, convincing digital delay sounds as well as convincing analog (especially tape) delay sounds (that would definitely include multiple head options) and has a resonable number of preset slots. The Empress Super Delay has a very interesting multi tap function, but without tape flavour. And I can't believe that Strymon didn't put the ElCapistan multi head options into the TimeLine 🙁 Sometimes I feel like just hooking my EchoBoy loaded computer to my guitar rack… That gave me the delay sounds I'm after but would bring some other pains… Life ain't easy 🙂
I would really like to have more influence on the pannings of the Eclipses' TimeFactor presets. Perhaps the [LEVELS] option in the [PARAMETERS] tree would be a good place for some future update… and would provide panning control on all presets and increase the overall usability A GOOD BIT. Some like:
[FXA MIX] [FXA LVL] [FXB MIX] [FXB LVL] > next page > [FXA PAN] [FXB PAN]
I'm not a specialist here, but i think that way the actual preset algorithms wouldn't need to be touched..?So, maybe you guys at Eventide could think about my proposal and if it's possible to include it without too much hassle.
I have another idea that is about an additional [IN MODE] routing option "Mono 3", that sums the inputs 1 and 2 and would result in one single mono source. Uhm, I'm going to write a separate post about those two feature requests 🙂
Cheers,
Sascha -
April 3, 2012 at 7:12 pm #123282
pinot
MemberHi Nickel,
thank you for that great work-out. Would it be possible for you to send me a mail with that
2 patches to try it? pinot@tmo.atKind regards Pinot
