Mute / Bypass
Home Forums Products Rackmount Mute / Bypass
    • #107173
      mikeeebeee
      I operate my Eclipse using a midi foot controller.  Program 1 is mapped to #1 on the controller, and so on.
      What I want to do is be able to step on switch #1 on the foot controller and have the Eclipse muted so no sound comes out (so I can set my instrument down without a big crash coming through the PA).
      I have set the bypass setting to "Mute All" so I can do this by touching the "Bypass" button.  But I want to be able to do it from the Midi foot controller.
      Appreciate help on how to do this.  Thx!
    • #120581
      achaput
      You could assign a program button on the controller to call up Program 100, "Mute Series".
    • #120588
      mikeeebeee
      But for reasons that aren't clear to me, when you switch bypass to "mute all" in the setup menu, it doesn't flow through to program 100.  Program 100 remains a bypass with the dry signal passing thru the eclipse.  You still have to push the bypass button to stop the signal from passing thru the Eclipse.
