Muting Output 1 on H90
Home Forums Products Stompboxes Muting Output 1 on H90
    • #187720
      CIW2025
        I’m setting up my H90 for a guitar rig with two external pedals as inserts. These two pedals use Return-in 3 & Return-out 3 and Return-in 4 & Return-out 4 respectively.
        The signal chain is:
        Electric Guitar one into Gig Rig Three2One
        Electric Guitar two into Gig Rig Three2One
        Acoustic Guitar into Gig Rig Three2One
        Gig Rig Three2One > into H90 input 1 > Output 2 into front of Twin Reverb – this works great.
        H90 Output 2 goes to a Mixing Desk PA
        When I switch from electric to acoustic guitar (using the Gig Rig Three2One to select guitar inputs) is there a way to mute output 1 in the H90 so that the acoustic guitar signal only goes to the Mixing Desk PA and not the Twin Reverb?
        The work around is that I put the Twin Reverb in standby but that means fiddling around the back of the amp between guitar changes…
        Thanks.
      • #187722
        joecozzi
          Did you mean to say Output 1 goes to the Twin?
          H90 Output 2 goes to a Mixing Desk PA When I switch from electric to acoustic guitar (using the Gig Rig Three2One to select guitar inputs) is there a way to mute output 1 in the H90 so that the acoustic guitar signal only goes to the Mixing Desk PA and not the Twin Reverb?
          No, there isn’t a way to bypass Output 1 and Output 2 independently. You might need an external mute switch or volume pedal for the signal coming out of Output 1.
          Just making sure: Are you using the Force Mono feature of the H90 found in the I/O section of the System menu? In this configuration it’s necessary because normally, if you connect to outputs 1&2 it makes the H90 function in stereo, not dual mono as it sounds you’re using it in your setup.
        • #187797
          CIW2025
            Hi Joe,
            Thanks so much for your reply (and sorry for the signal chain SNAFU!) it means I can move on and find a workaround.
            I have made the change to Force Mono too, thanks.
            Cheers
            Chris
