Home › Forums › Products › Stompboxes › Natural Feedback Creation Algo for H90
- This topic has 10 replies, 4 voices, and was last updated 3 years, 3 months ago by
brock.
June 18, 2023 at 4:48 pm #172005
it would be nice to add this feature in some pitch algos or create a dedicated one maybe.
June 18, 2023 at 10:34 pm #172008
I have built some on the H9000, but not sure I can migrate them to the H90
June 19, 2023 at 11:51 am #172011
I’m curious on how you structured that (the component algorithms / patching you used).
I have a POG-like Program (DynaVerb OmniPressor -> PolyPhony) that I’ve considered modifying as a natural harmonic feedbacker. Perhaps using the HotSwitches for FreqOut-like harmonic switching. I’d need to re-configure some kind of trailing sustain into the mix.
June 21, 2023 at 8:23 am #172066
June 21, 2023 at 8:56 am #172068
There are a few up on PatchStorage, with more in the wings. They get reasonably close, but are far from perfect.(I’ve gotten side-tracked lately on the impossible task of emulating all 32 Lexicon Vortex algorithms).
If you d/l this particular one, the DynaVerb Threshold of -12.0 dB is too high of a trigger level for most systems. Dial it up to ~ -36 dB (+/-). I need to fix that one.
June 21, 2023 at 6:29 pm #172090
These Vortex emulations are relevant to my interests, and I wish to subscribe to your newsletter!
June 21, 2023 at 7:01 pm #172096
Quite frankly, I am catching Holy Hell by attempting to pull this off. I have a Vortex here for 1:1 later on, but I wanted to get the H90 algo selection & placement down first. No preconceptions.
Which means trying to cram 4-8 distinct effects into two Presets, without relying on Inserts, or any non-standard external controllers [envelope follower]. True audio morphing is a lost cause; some of the cross-feedback routing just can’t be done (so far).
I’m shooting for accuracy (otherwise, what’s the point?), but I may have to settle for “Inspired By”. Or leaving out some of the “Registers”.
Then again, every time I revisit the project, I get a “What if I used *this* algo instead?”. So, still clinging on to hope here …
July 10, 2023 at 10:23 am #172364
July 10, 2023 at 9:05 pm #172376
I’m curious on how you structured that (the component algorithms / patching you used). I have a POG-like Program (DynaVerb OmniPressor -> PolyPhony) that I’ve considered modifying as a natural harmonic feedbacker. Perhaps using the HotSwitches for FreqOut-like harmonic switching. I’d need to re-configure some kind of trailing sustain into the mix.
The manual with the block diagram for one example is available here – https://godlike.com.au/fileadmin/godlike/patch/h9000/manuals/Dub_Delay_Para_User_Guide.pdf
On the H9000 its possible to completely rewire things at the algorithm level, whereas the H90 seems to be more like rearranging existing algorithms, similar to a H9000 chain (I don’t own a H9 or H90). I’m not sure if it is possible to load a custom algorithm onto the H90 without Eventide’s help. I suspect that they use the same toolkit to build the H90 algorithms, but pretty sure they have a custom tool to prepare algorithms for the H90, as opposed to the H9000.
July 11, 2023 at 4:36 am #172382
on the h9/h90 there is no way to “deep” modify algos, you can use only 2 algo on h90 (paralles or in series), you could put a second h9/h90 in the insert of other h90 for example, but it will be trickier to setup things
July 11, 2023 at 8:26 am #172383
The manual with the block diagram for one example is available here – https://godlike.com.au/fileadmin/godlike/patch/h9000/manuals/Dub_Delay_Para_User_Guide.pdf On the H9000 its possible to completely rewire things at the algorithm level, whereas the H90 seems to be more like rearranging existing algorithms, similar to a H9000 chain (I don’t own a H9 or H90). I’m not sure if it is possible to load a custom algorithm onto the H90 without Eventide’s help. I suspect that they use the same toolkit to build the H90 algorithms, but pretty sure they have a custom tool to prepare algorithms for the H90, as opposed to the H9000.
Thanks for that. Compression in a feedback loop (using a Beebo through the Inserts) showed promise. It’s going to be a challenge to translate that to a universal H90 setup.
