Since I imported files from my H9, I have encountered a slight problem.
Some presets appear with white display letters, while others appear gray.
The major difference between the two is that when I navigate through the Presets, the “white” presets I need to press Active only once, while the gray presets I have to press twice.
Is it possible these presets you imported were saved in an inactive state on the H9? Either way, it seems this can be corrected by activating each program and resaving to the same position.
