Need to use the H9 for a db boost live!
Home Forums Products Stompboxes Need to use the H9 for a db boost live!
Viewing 3 reply threads
    • #112467
      opus1
      my main amp went down. NEed to set up a midi channle that puts out more DB. A led boost channel. Can each individual preset have its own Out put volume or is there only a global setting?
    • #127682
      gkellum
      Yes, each preset has an output level control that's saved with the preset.
    • #138709
      jnorris
      I can't seem to get to that option on the pedal, even in expert mode. Any suggestions, other than IOS or computer? Thanks in advance.
    • #138714
      gkellum
      If you long press the left footswitch, it lets you adjust the gain.  Depending on whether the left footswitch is in active or bypass, it will let you adjust input level or output level.  The exact details are described in the H9 user manual.
