New Eclipse
Home Forums Products Rackmount New Eclipse
Viewing 7 reply threads
    • #111069
      millertime
        I just received my second eclipse. It was a used unit with version 2 software, hardware version A
        I did the software update to V4. My question is how many hardware versions have there been?
        can I find out how many on time hours this unit has?
        how can I find out the status of the battery or should I change it now?
        I would like to find out the age of this eclipse…   thanks wayne
      • #124749
        wilkinsi
          AFAIK, only the top end harmonizers like the H8000/Orville/DSP7000 series had the ability to store the number of hours etc.
        • #124750
            Mr Wilkinsi is correct-  the Eclipse does not show its age.
            There have been a number of small hardware mods to the Eclipse to improve reliability and replace unavailable parts – but if yours is behaving well these should not be an issue. There have been no major changes.
          • #124755
            millertime
              Ok guys thank you for the responce. V4 is up and running fine. I really like useing the Eclipse in a guitar rack and im looking forward to getting this set up tonight and doing some work with itBig Smile
            • #124757
              millertime
                I was getting a bad checksum memory error until I read what to do in the manual when this happens. It seemed to take care of it. Hope I dont see that again
              • #135583
                wilkinsi
                  If you do, you can also change the lithium battery and then flash the firmware using a CF card.
                • #135585
                  millertime
                    what do you mean by " flash the firmware "
                  • #135587
                    wilkinsi
                      As in the same way you updated to V4 firmware.
