New Eclipse owner question
Home Forums Products Rackmount New Eclipse owner question
    • #105760
      Can I use the Eclipse as 2 seperate mono processors and have one effect on my vocal and one on my guitar? If so, how is this done?
    • #117717
       There is a way to configure Eclipse as 2mono machines:
      -first you need to set the preset ROUTING to DUALMONO, under the PARAMETERS key.
      -you need to use both inputs and outputs
      -the presets you will use(create need to have 2 algorithms loaded, each one in each FX block
      !!! Make sure you only use DUALMONO routed presets or wrong audio results will happen!!!
      best
      I
