New Fangled Elevate VST3 not loading in Ableton 10.1.35
Home Forums Products Plug-Ins New Fangled Elevate VST3 not loading in Ableton 10.1.35
Viewing 5 reply threads
    • #157811
      Hi Stefan,
      Can you try doing a deep scan of your plug-ins in Ableton? Go to Preferences > Plug-ins and Option/Alt-click "Rescan" to force a deep rescan.
      Let me know if it shows up after that.
      -Tyler
    • #157818
      stefandj
      Yes, I did that before and after I reinstalled the bundle. Ableton also scans for plugins on startup so the folders have been scanned quite a few times now.
    • #157820
      stefandj
      Ok, I Should have read your comment better before I replied. The plugin indeed shows up after a DEEP scan. I forgot about that function.
      Thanks Tyler!
    • #157825
      No problem, glad that you were able to get it to show up!
    • #116491
      stefandj
      I just bought and installed the Elevate Bundle and all VST3 plugins are loading in Ableton except Elevate.  All plugins are located in the same folder.  I later removed the bundle an reinstalled it now also wtith the VST2 plugins. These are all showing up. what can be wrong with the Elevate VST3 plugin?
      P.S. I just tried to attach screenshots to this post, but that function seems broken as well
      P.S.2 Editing and adding the screenshots does work 🙂
      BR, Stefan
    • #157834
      DGillespie
      Thanks Tyler!  I had not thought of that either.
