New plugins crashing Cubase
Home Forums Products Plug-Ins New plugins crashing Cubase
Viewing 10 reply threads
    • #115383
      lahatte
        I downloaded the latest versions of H3000 Factory and EQuivocate. After installing, Cubase blacklists them, and if I try to reactivate, Cubase crashes. The old plugins do not have that issue.
        Does anyone know of a fix??
        Thanks.
      • #152164
        Sorry to hear you're having this issue. Can you tell me what OS version and Cubase version you're using?
        Sometimes issues like this can be resolved with these steps:
        1. uninstall the plugins in question
        2. open Cubase and rescan for plugins
        3. deactivate and re-activate the licenses in the iLok License Manager
        4. re-install the plugins
        5. open Cubase and rescan for plugins
        Hope this helps,
        Ryerson
      • #152167
        lahatte
          I have done all of that except deactive in iLok. I will try.
        • #152169
          lahatte
            Ok, I tried the deactivate thing after uninstalling. Still the same result after reinstall.
            Please advise.
            Thanks.
          • #152170
            lahatte
              Oh, Cubase 10.0.2, and Windows 10.
              Also, I found the old version in my recycle bin, and I can install it and Cubase has no problem with it.
            • #152171
              Interesting, thanks for the info. What's the version of the plugin that works?
            • #152172
              lahatte
                For the H3000 I have 2.7.5. For EQuivocate I have 1.0.1.
              • #152173
                lahatte
                  I can say that one time, with some unknown combination of install steps, the older H3000 got blacklilsted, but I could restore it without crashing Cubase.
                  But that might be a remnant of Cubase having a record of H3000 (the new one) being blacklisted. In other words, I may not have refreshed the VST list prior to reinstalling the old version. So, maybe that doesn’t help, but I wanted to trough it out there.
                • #152266
                  Audesi
                    I have this same issue. Haven’t been able to get H3000 Factory to work in Cubase 10 since I bought it. I can get it unblacklisted. But then when I load it in an insert, it automatically crashes Cubase. I’m on the latest  version of Cubase currently, 10.0.30
                  • #152275
                    tlongabaugh
                      What OS are you using?
                      Please make sure you have the latest iLok License Manager (www.ilok.com) and H3000 Factory installed.
                    • #152297
                      hcsametzki
                        Hi, I had a similar problem with Blackhole and the Ultrachannel. I could fix the problem (I had help from the
                        support) by running Cubase 10 as an administrator. You can do this by rightclicking the cubase-icon (I’m sorry,
                        I’m using the german version of windows – so this won’t be very precise…) settigs – compatibility – check “run as administrator”.
                        Hope this helps…
                        Hans-Christian
