January 12, 2011 at 6:43 pm #107554Frank PearlParticipant
Hi there
I'm an Eclipse V4.01 user. I use it with a Ground Control Pro. I use the channel 2 on GCP and Midi Channel 2 on the Eclipse.
I programmed 3 IA switches on GCP: 1 for the tap tempo ( ext.1 – source: midi single – channel: base + 3 – CNTRL 68) 1 for FXA Bypass (ext.2 – source: midi single – channel: base + 1 – CNTRL 70 – Triggered ON/OFF – sense reverse) and 1 for FXB Bypass (ext.3 – source: midi single – channel: base + 2 – CNTRL 63 – Triggered ON/OFF – sense reverse).
They work fines. I succeed to tap the tempo and to bypass the effects.
This is my issue. Everytime i tap the tempo when i'm playing, I can no longer hear the effects. It 's like every time I tap the tempo the eclipse was going to bypass. To rectify this I have to reload the preset. If I tap again, you hear only the dry signal.
I tried to fix the memory, to reset the eclipse, to return to factory default. Always the same problem. Any Solution??
thank you
Frank Pearl
January 12, 2011 at 6:51 pm #121386
My guess is that if you pick different ext numbers, the problem will go away. Ext1-4 are often pre-programmed into the effects, so will be doing more than you think. Try ext5 and above.
January 12, 2011 at 7:35 pm #121388Frank PearlParticipant
Thank for the fast answer.
I followed your advice, using EXT5, and EXT6 and EXT7 but the problem remain the same. It's like i have a dry guitar sound after i tap with GCP.
January 12, 2011 at 7:58 pm #132571
What preset does this happen with. (Give numbers for 1 or 2, even if it is all of them).
Do you get the same effect with the TAP button ?
January 12, 2011 at 9:40 pm #132572Frank PearlParticipant
well i 'm using the preset n°255 and no problem with the tap button: it works fine.
another issue: when i change preset, like Ballerina, the eclipse charges the preset but i can't hear the effect. Always after i push the load button (soft key), it works fine.
Why this??
January 12, 2011 at 10:21 pm #132574
Frank Pearl:
How are you changing the preset ? If you select a preset from the front panel you ALWAYS have to hit <LOAD> to hear it.
January 12, 2011 at 10:35 pm #132575Frank PearlParticipant
i change presets always with my GCP
