New to H9
Home Forums Products Stompboxes New to H9
Viewing 4 reply threads
    • #111966
      Hi im new with eventide and especially H9.
      in the new H9, is there anyalgorithm whereby the combination of reverb and delay or reverb delay chorus or delay and tremolo etc etc.
      I just purchased it and i found that normally most algorithm comes in 1 type of modulation. Eg: if delay section only delays.. there is no combination.
      Hope to hear some advice.
      Thank you.
    • #126764
        The H9 Algorithm Guide is your best resource here (followed by H9 Control help files and 5-minute Store demos).  There's a short description of each algorithm structure above the individual parameter descriptions.  Many of them contain multiple effects. Some combinations are not that obvious on the first glance.
        An Eclipse-like block diagram of each algorithm would be helpful, for those who are curious about how the effect parameters are routed.  I think that would be helpful in visualizing the signal path, and ironing out some of the written ambiguities.  That said, I've used some forum post research and older Eventide documentation to fill in many of the blanks.
      • #126772
        thanx brock for the reply.
        It helped me alot.
        Thanx again
      • #126788
        Check out modechoverb in space algo's.  It does the rever with delay and you can add chorus or flange to it also.  Or you can use each individually.  Great algo.  Hope this helps.
      • #126793
        Motozee:
        Thanx alot motozee.. will do check out the algo. after reading the manual it seems thats a lot of effects combined. You need to really hear it..
        all this while.. its a a straight forward process.. but for eventide i have to read the manual.. hehehe..
        Thanx again guys…
        Appreciate it.
