Newest Update
Home › Forums › Products › Stompboxes › Newest Update
Viewing 15 reply threads
    • #185252
      Musicman52
        I just finished the newest update successfully. However, when I now click on “connect” my pc screen goes right back to my desktop. Why is this?
        Thanks.
      • #185256
        jac2982
          Same thing with me. I have a problem when I connect via USB through my MacBook, and I can’t connect via Bluetooth through my iPad. All of these problems started after I updated today. I have to prepare for a performance tomorrow, so it’s a very difficult situation.
        • #185257
          tpluta
            If you’ve updated to the latest Public Beta H90 Software (1.9.4), you’ll also need to install the latest Public Beta version of H90 Control (1.8.6):
            Windows: https://www.eventideaudio.com/downloads/h90-control-windows-public-beta
            macOS: https://www.eventideaudio.com/downloads/h90-control-macos-public-beta
            Note that this version of H90 Control is not yet available for iPad. Let me know if installing this version of H90 Control resolves the connection issues.
            EDIT: H90 Control 1.8.6 for iPad is now available via TestFlight: https://testflight.apple.com/join/q7BN23Xd
            • #188657
              garyslama
                “Public Beta version of H90 Control (1.8.6)”
                Did you mean 1.8.16?
              • #188665
                  No, this is an old thread.
                  The current version of H90 Control is 1.8.16
              • #185258
                jac2982
                  The problem has been solved. Thank you.
                • #185265
                  Musicman52
                    Problem solved. Thanks!
                  • #185279
                    headfirstonly
                      Came here to report the same issue; installing the new 1.9.4 public beta of H90 control fixes the problem. Cheers, folks!
                    • #185286
                      Stratmaster
                        Well something went seriously wrong for me. First the H909 control app on my Mac crashed repeatedly when trying to connect. When I installed the 1.9.4 I could get the H90 control to start and connect to the pedal but now my H90 has reset itself. All my programming is lost and on top of that the pedal looks ok but there is no effects added to the sound in any program. I reset it for dual routing and the routing works but I get no effects from the H90.
                      • #185287
                        Stratmaster
                          I did a factory reset but still no effects beeing applied to the sound from the H90. It passes sound throu the dual routing but no effects. Something went serously wrong with the update.
                        • #185320
                          Stratmaster
                            Problem solved with the help from Eventides excelent customer support!
                          • #185329
                            honeybrew
                              I’ve installed https://www.eventideaudio.com/downloads/h90-control-macos-public-beta (fresh), and on login screen I’ve error (I’m providing correct credentials, as I can login here with the same).
                              Screenshot 2024-10-11 at 15.04.10
                            • #185331
                              honeybrew
                                Update: I’ve used username instead of e-mail and was able to login.
                              • #185353
                                Ulifox
                                  Hi there,
                                  Do you have an approximate release date for the latest IOS app update? It is really useful when on the road with my I padpro.
                                  Thank you.
                                • #185385
                                  logicbdj
                                    I updated to 1.8.6 and I cannot gain access on my computer via USB. It gives me the message Software Update Required. No idea where to get this update, as I went to the downloads section and don’t see anything beyond the 1.8.6 update. Do I need to update the unit itself, and where is that file?  Thank you. Using Windows 10.
                                  • #185387
                                    logicbdj
                                      You can click the cloud icon in the corner of the H90 device in H90 Control to update the H90 software. You need to update the pedal to H90 software version 1.9.4 to work with this version of H90 Control. See #7 on the list here for the update icon: https://cdn.eventideaudio.com/manuals/h90/1.9.4/content/h90-control/home.html
                                      Unable to click on the cloud icon… it’s not lit to select, and clicking on it does nothing.
                                      • #185395
                                          Try click the X icon to delete the H90 from H90 Control, and then go through the “Add Device” steps again. Can you now click the cloud icon after adding it again?
                                        • #185422
                                          logicbdj
                                            Thanks. I did that yesterday and it didn’t work… but it did today. Go figure.
                                          • #185424
                                              Glad to hear this is resolved. Sorry for the inconvenience.
                                          • #185447
                                            Karis
                                              I tested the new update on my playlist (controlled by a morningstar MC6-Pro) and there are a few MIDI differences (nothing too bad since i corrected quickly).
                                              1) Before the update i could change Mode before or after loading a preset (same thing, no problem). Now i’ve got to change mode before loading or the behavior is weird (works sometime, not everytime and also sometime goes to PErform page 2)..
                                              2) Apparently i’ve got issues with the P act/bypass CC message. It was bypassing my program before, no it has no effect (i used  load CC instead and it works).
                                              Like i said, nothing too bad. Just reporting weird things in case it helps.
                                              REgards.
                                              • #185456
                                                  Thanks for taking the time to test the new update and post here. Can you please provide some more information?
                                                  1) Please describe in more detail what operation you are doing here. Are you changing from Select / Perform mode? Is this being done using MIDI? Note that the perform page will now be saved in the Program. For example, if you save the Program while on Perform page 2, when you load that Program it will automatically be on Perform page 2. The next Program may use Perform page 1 if that’s what page it was on when it was saved. I’m not sure what the difference you are describing is by changing modes before/after a Program is loaded, so please help me understand this better.
                                                  2. You must use a CC message of 64 or higher to toggle the Program bypass on/off. If using momentary Program bypass, a CC value of 63 or lower will bypass the Program, a value of 64 or higher will make it active. Please confirm that your MIDI controller is configured to send these CC messages properly.
                                              • #185465
                                                Karis
                                                  Thank you for your answers.
                                                  First let me say i was not aware of the changes you mentionned, and i think these changes are great. Saving the Perform along with the Program is a wonderful idea (saves a few midi messages). But, as my playlist was working great, i did not noticed this change. So just for the sake of maybe detecting a bug, here is what i was doing.
                                                  H90 on MIDI channel 4. The chain goes from Mc6Pro (Midi Channel 1) through an HX Stomp (Midi channel 2) to the H90 In.
                                                  1)
                                                  In MIDI Global:
                                                  CC#98 assigne to Select Mode (not relevant here)
                                                  CC#99 assigned to Bank Mode (not relevant here)
                                                  CC#100 assigned to Perform Mode
                                                  Calling Program 10 in Perform mode: i sent a CC#100 and a PC#10 to the H90 (MC6-Pro being the controlling machine). The order of these 2 messages was not relevant in previous firmware, but i noticed in the new firmware CC#100 must be launched before PC#10 or weird things happens.
                                                  That said, maybe it is connected to the new functionnality you pointed (and as i plan to remove these messages now that i know i can save the mode with the program, it is not a problem).
                                                  2)
                                                  I’ve got a program (let’s say Program 1) with P and A on by default (B is off) , and want to call this program AND deactivate P immediately..
                                                  in MIDI Global I’ve got
                                                  CC#14 assigned to P Act/Byp.
                                                  CC#1 assigned to Load.
                                                  Previous firmware. Launching PC#1 and CC#14 with a value of 127 was deactivating P. Not working on new firmware
                                                  Also tried PC#1 and CC#14 with a value of 0 (no more effect).
                                                  But (new firmware) : Launching PC#14 and CC#1 with a value of 127 works. So that’s enough for me anyway.
                                                  Hope it helps, but, as i’ve said, No real deal : everything is working fine.
                                              • The topic ‘Newest Update’ is closed to new replies.
