Newfangled Audio Generate – no audio is produced in Ableton live 11-12
Home › Forums › Products › Plug-Ins › Newfangled Audio Generate – no audio is produced in Ableton live 11-12
Viewing 5 reply threads
    • #182118
      stefano.cancedda
        Hello, I’ve noticed a strange problem in the VST3 Generate plugin version when it’s loaded in Ableton Live. It happens sometimes, that in a project with Generate on a track (a track in which I worked normally, saving MIDI notes, change the parameters of the path, etc.) after quitting Ableton normally and after opening it again, say the day after, then that instance it doesn’t produces sound anymore. the GUI shows that it’s receiving MIDI data and the graphic and the meters are pumping but the area with the out it’s off and no meter is showing signs of activity and naturally no sound can be heard.
        I cannot find a cause for this problem, or how to solve it (I’ve done some trials disabling opnegl graphics, or disabling effects, things like these, but the problem persists). I only managed to replace the VST instance of Generate in the track with a new one (I have to save the patch in a user preset naturally) and start again with a new one. This weird behavior is not always occurring, but I noticed it was already happening in Ableton Live 11 suite, so I waited for the release of the 12 version thinking that maybe the new version could had solved the issue. Ableton Live support advised me that is a plugin problem.
        I’m running the latest version of Generate in a MacOs Apple Silicon M2 processor System.
        thank you.
      • #182394
        ko19
          I’ve got exactly the same issue, and I’m also in the dark regarding a fix. Thought I was the only one with this issue – it’s so strange. Interestingly I have an M2 Max CPU, so the same family of chip. I would recommend getting in touch with Dan at Newfangled, and I will do the same.
        • #182852
          FREETHINKER
            Yes me too, what a pain!
            I reinstalled it and it worked for a few minutes. Now when I select a preset it take approx 10 seconds to load.
            Shame as it was my favourite synth. Hope someone can help
            Chris
          • #183553
            charbwoy
              I have the same problem in Reaper, plugin loads and midi is registered on the track, but no audio is triggered from Generate.
              replacing the plugin with another synth produces audio
              MacOS 12.7.5 / Reaper 7.17
            • #183578
              DGillespie
                Hey guys, sorry we’re looking into this.
                Dan
              • #183583
                charbwoy
                  Update:
                  I re-installed Generate, rebooted my machine, and it now works as normal.
                  I did this after reading the other posts and so it’s been a few days now and the sessions are loading fine and it works as expected.
                  I didn’t re-download the installer either as i still had it in my downloads folder.
                  I use the AU format, on an M1 Mac, with all software running natively.
