Newfangled Audio Generate problem? – Audio hangs/sustains
Home › Forums › Products › Plug-Ins › Newfangled Audio Generate problem? – Audio hangs/sustains
Viewing 4 reply threads
    • #175156
      Twoears
        When I disable vactrol modelling on the wavefolder, and modulate the frequency (all the way to the right) with S+H, LFO, key, velocity, TMB, and some envelope release times, the audio will decay after release, but then sustain/hang for ~1s at the very end.
        If I enable vactrol modelling, there is no sustain/hang after release.
        Is this how it’s supposed to function, or is there a problem?
        I’m using Reaper v7 if that matters. It was also happening in v6, but I only just narrowed down what was happening/causing it.
        Sorry if this was poorly explained, I can make a short video demonstrating the problem if that helps.
        Thanks
      • #175157
        Twoears
          Actually you don’t even need to modulate the frequency, just seems to be happening when vactrol model is disabled.
        • #175545
          Twoears
            Here is a 35s clip of the issue.
            It was nothing to do with modulation, it simply happens when I disable vactrol model. Generators, wave folders, voices, etc, don’t change the outcome.
            Generate v1.5.6
            REAPER v7.03
            AMD 5600x, 32GB RAM, NVMe drive
            This also happens in Pendulate.
            I contacted both Newfangled / Eventide support a couple of weeks ago, but I haven’t received anything back..
            Hope someone is able to help me solve the issue.
            Thanks.
          • #175701
            DGillespie
              Hey sorry, we can reproduce this and should have a fix available soon.
            • #175702
              Twoears
                That’s great to hear, thanks.
