June 22, 2014 at 6:56 pm #111732Unit DubstepMember
i am trying ti install UltraChannel and when i go into the ILock license manager there is no activation code. there is a location ID but I'm not sure what that is. is there a problem her, or am i just being ignorant. Please help. mush appreciated.
June 24, 2014 at 9:50 pm #126204
Hi Unit Dubstep,
To receive an UltraChannel License you need to register on this page:
http://eventideplugins.elasticbeanstalk.com/ultrachannel.jsp
If you don't have an activation code you will get one by clicking on the FAQ.
When you register you put your ilok.com account name and it will send a license directly to your ilok account. Then you can authorize it on your computer or iLok using iLok License Manager.
Thanks,
Dan
June 25, 2014 at 3:33 am #126210Unit DubstepMember
Hi Dan,
I have already registered and linked my ILock account and everything
June 27, 2014 at 8:08 pm #136887
Hi Unit Dubstep-
Is the UltraChannel license showing up in your iLok account in iLok License Manager? If so, you should be able to either pull it onto your iLok dongle or onto your computer on the lefthand side of iLok License Manager.
Tom Longabaugh
Eventide
June 28, 2014 at 5:04 pm #136898Unit DubstepMember
Hello Tom,
When i drag over the license it gives me an error summary and says UltraChannel will not be installed and my only option is to click "ok"
June 28, 2014 at 5:33 pm #136899Unit DubstepMember
the license is activated but what do i do after?
June 30, 2014 at 3:00 pm #136917
Hi Unit Dubstep-
If the license is activated UltraChannel should show up in your DAW. If it does not, I would rescan your plug-in folders from your DAW (this is usually found in your DAWs audio settings).
