No audio pass-through at all in pre/post setup (modfactor)
Home › Forums › Products › Stompboxes › No audio pass-through at all in pre/post setup (modfactor)
    • #116055
      EyeballJackson
        I’m having difficulties with pre-post setup on my modfactor.
        After carefully configuring the cables, I’m not getting any audio throughput at all, whether active or in bypass.
        Is there a setting that isn’t compatible with pre/post that I might have activated without realizing it?
      • #155601
        bohan
          EyeballJackson wrote:
          I'm having difficulties with pre-post setup on my modfactor.
          After carefully configuring the cables, I'm not getting any audio throughput at all, whether active or in bypass.
          Is there a setting that isn't compatible with pre/post that I might have activated without realizing it?
          Do you get any signal if you just use IN 1 & OUT 1 or IN 2 & OUT 2?
        • #155605
          EyeballJackson
            I got it figured out! User error.
            Thanks for the reply!
