no dry signal
Home Forums Products Stompboxes no dry signal
Viewing 3 reply threads
    • #105730
      jzucker
      I am not getting any dry
      signal in the mix control. With the mix control set all the way to dry
      signal there is no guitar signal coming out. This is using mono in and out, amp level with guitar plugged straight in to mono in, mono out going to amp.
       Additionally, if I hit the bypass button, I get no signal. I do get signal if I unplug the unit.
      Anyone?
    • #117659
      Roobin
      Make sure Killdry is set to Off.
    • #117660
      wes
       Go into your settings and make sure KILLDRY is off.
    • #117661
      jzucker
